Accessing Back Side of Instrument Panel - Tips?
HiFlite
Title says it. How do I get back there? Does the panel unscrew and pull forward? Or does the shield over it somehow pop off? Or do I somehow stuff myself into the foot well with the stick up you my know where? 😲
On my Ximango (#135) the top of the panel is a piece of molded plastic. Remove the hex head screws on either side and it lifts off straight up. Very easy, takes less than a minute.
  • Like 1
Lowest screw on each side holds the instrument panel on, but must be loosened; remove the next two higher ones on each side, and it slips out. Thanks!
