Jim Lee Posted September 21, 2022 Report Share Posted September 21, 2022 This just in from Pure Flight: TURBULATOR on the tail Clean the place for the turbulator. Bring the aircraft into flight position. Measure the appropriate distance according to the picture and mark auxiliary points with colored tape. Stretch the colored tape from top to bottom so that it starts almost at the top and ends just short of the cover of the rudder control rods. Make sure that the tape is as straight as possible and will help you stick the turbulator correctly. Stick the turbulator at a distance of approx. 50 mm from the upper edge. Its length will come out exactly. Keep a safe distance from the tape so that it can be removed after sticking the turbulator. We glue the turbulator by gradually tearing off the adhesive covering layer by tip. Finally, just remove the colored tape. TURBULATOR on the wings The turbulator on the wing sticks to the underside of the wing. Clean the place for the turbulator. The principle of gluing the turbulator is the same as gluing the turbulator to the tail. The wing can be glued together with mounting on the plane, but you can't do it in one person. An easier way, both for the correct measurement and the actual gluing, is to turn the assembled wing and place it on some benches. For the correct distance, it is necessary to have the flap in the 0° position. In the green lines, we will measure the distances according to the picture. We mark the distance with squares of colored tape. We will connect these points with colored tape (with 2 people you will achieve better directness and accuracy) For the possibility of replacing the wing extension with a winglet, the turbulator must be cut at the cut position. Finally, just remove the colored tape. Quote Link to comment Share on other sites More sharing options...
Registered Eric Greenwell Posted November 29, 2022 Registered Report Share Posted November 29, 2022 What do you gain with the zig-zag on the rudder and the wings? Is it just a better glide ratio, or are there safety and handling improvements? Has anyone done this? Any comments? what zig-should be used? The drawings show a fairly large pitch for it. And how thick should the ZZ be? 1 Quote Link to comment Share on other sites More sharing options...
Foley Posted November 29, 2022 Report Share Posted November 29, 2022 i presume it would be to reduce incidence of the high speed rudder flutter we've talked about before. To limit disruption of airflow. Quote Link to comment Share on other sites More sharing options...
Rob Posted December 1, 2022 Report Share Posted December 1, 2022 Quote Link to comment Share on other sites More sharing options...
Rob Posted December 1, 2022 Report Share Posted December 1, 2022 Just now, Rob said: Quote Link to comment Share on other sites More sharing options...
Rob Posted December 1, 2022 Report Share Posted December 1, 2022 Copied this from Pure-flight Quote Link to comment Share on other sites More sharing options...
Jamey Jacobs Posted December 17, 2022 Report Share Posted December 17, 2022 The handling improvements are very enticing and worth the effort to install these turbulators. I know it was asked before, but zig zag turbulators on many sailplanes improves L/D glide performance by a measurable amount (5% is reported in some cases). Is there any experience with zig zag tape as described on the Phoenix glide performance? Quote Link to comment Share on other sites More sharing options...
