How to remove a rear speaker grill?
Eric Greenwell
I'd like to remove/change the vario speaker, which is under the speaker grill behind the passenger, but I don't see any way to remove the grill. How do you remove the grill?
Eric -
If I understand your question correctly, you just pry gently and evenly between the speaker grill and the panel it's mounted on. I've removed my speaker grill several times to install a tray to mount my SPOT using the space between the grill and the panel.
Russ
