Rally2B Posted October 25, 2018 Report Share Posted October 25, 2018 Just received a letter attached to a survey asking if there is any interest in an engine replacement package using the Rotax 912. This was sent to me by Grob Aircraft along with some technical specifications. I believe they are looking to see if there is any interest and if so they may proceed with development. No costs were mentioned but I would like to see them develop an engine replacement just in case I need it later. Attached is a copy of the letter and they would like a response no later than November 15th. Please consider responding if you have not already done so. Thanks, Robert Grob Aircraft Factory G 109B engine conversion survey.pdf Quote Link to comment Share on other sites More sharing options...
Grobber Posted November 14, 2019 Report Share Posted November 14, 2019 Does anybody know if the Grob Aircraft factory has decided on a direction based on the survey yet? Cheers. Mike. Quote Link to comment Share on other sites More sharing options...
CarlMims Posted June 17, 2021 Report Share Posted June 17, 2021 Does anyone know the outcome of this? The email address in the letter bounces. Quote Link to comment Share on other sites More sharing options...
El_Guapo Posted March 2, 2022 Report Share Posted March 2, 2022 Grob has released the drawings to change from a Grob 2500 to a Rotax 912. It is in a service bulletin under the "General" portion of downloads. According to the same service bulletin, the Grob 2500 is now 'obsolete'. Southern Sailplanes recovered from 2500s as part of "Project Able" but now shows all of them as sold out. 1 Quote Link to comment Share on other sites More sharing options...
xintersecty Posted March 23, 2022 Report Share Posted March 23, 2022 Here is the PDF for the service bulletin. Basically it says, it has been certified with no technical details. 817-71_Rotax_912iSc3.pdf Quote Link to comment Share on other sites More sharing options...
