Rally2B Posted September 13, 2021 Report Posted September 13, 2021 Has anyone replaced their Grob 109B brake hoses that interconnect the rudder pedal brake actuators to the reservoir and the rigid brake lines to the wheel brakes? If so, where did you get the brake hoses? Typical aircraft hoses can usually be fabricated by various aircraft sources but those for the Grob are meant for DOT 3 brake fluid and typical aviation suppliers cannot supply them. Mine are getting worn and need replacing. Any suggestions and “lessons learned” are greatly appreciated! Robert Grob 109B N300BG Quote
