Newshound Posted January 5, 2012 Report Posted January 5, 2012 I've been using Avgas in my 912 (#113) with AV-9 from CPS. But now my AP/IA, says that Lockwood is recommending Shell Aerosport 4. What say...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 G'Day, I have recently bought a half share in a Ximango 200 serial number 077 and have to replace the 80Hp Rotax motor as it has run out of calender...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 Shared via XOPA member Matt Mazur: Very Cool video of pilot Alberto Sironi in his Ventus 2 CXT. 11 hour flight (the video is not quite as long,...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 The 2011 TMG Fly-In was a roaring success. Twenty-four (24) ships graced the flight line, including: Grob, Taifun, Ximango, Stemme, Lambada, Samba,...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 hello the steel bracket on the tailplane which connects via two spigots on the fin has become worn. one of the two holes that the spigots go through...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 Hello all, Curious to find out if any other Ximango owneres have experienced any starter problems with their ships? I have a problem that has...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 Yesterday I found that the button at the end of the locking lever on my starboard wing had unscrewed itself from the spring loaded rod it depresses...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 I am performing server maintenance and migrating the site to new server with a new host. Just FYI I am leaving a site on a shared server with...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 Greetings Team, I refueled on Sunday just before a fabulous soaring flight and my left fuel gauge suddenly started reading empty. I buzzed the...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 Ladies and Gentlemen: I had my engine overhauled at the last annual (Lockwood did a great job) and I decided also to change all hoses since the...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 Hello all: My annual was successfully completed today, but my mechanic raised two questions I could not answer immediately. First he asked where...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 I just received the message below, March 25, 2011. Wondering if anyone else has received a similar message from SPOT, the satellite tracking system? ...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 Hello All: I wonder if someone can sketch the tool for removing the bolt that holds the horizontal stabilizer. Mine seems to have gone missing. ...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 Greetings all, I just finished the first two elements of Lockwood Aviation/Aerotechnical Institute's Rotax 912/914 engine course and I wanted to...More... Quote
Newshound Posted January 5, 2012 Author Report Posted January 5, 2012 I needed to replace a rough control bearing on my Ximango SN 161 on the aileron bellcrank arm (part # 27163) These bearings have an MS part number...More... Quote
Steve Sliwa Posted January 5, 2012 Report Posted January 5, 2012 I will use this thread to collect inputs from the forums at XOPA.org Quote
Newshound Posted January 15, 2012 Author Report Posted January 15, 2012 Colleagues I have been working with the organizers of the West Coast Touring Motorglider Fly In to develop the Touring Motor Glider Association...More... Quote
Newshound Posted August 14, 2012 Author Report Posted August 14, 2012 Hi guys, I am badly in need of a replacement lower gear leg for my Ximango. Chuck has been trying to get one from the factory 6 months to no avail....More... Quote
Newshound Posted August 15, 2012 Author Report Posted August 15, 2012 Hi guys, I am badly in need of a replacement lower gear leg for my Ximango. Chuck has been trying to get one from the factory 6 months to no avail....More... Quote
Newshound Posted August 15, 2012 Author Report Posted August 15, 2012 My ship has developed all of the sudden a loud whisling noise only when I am ascending, same with engine on or engine off in a strong thermal and at...More... Quote
Newshound Posted August 15, 2012 Author Report Posted August 15, 2012 Need to replace fuel cap. (lost in flight!) Any suggestions? Thx BruceMore... Quote
Newshound Posted August 15, 2012 Author Report Posted August 15, 2012 Does anybody know about a used Ximango for sale? Horst Stratmann N06SXMore... Quote
Newshound Posted August 15, 2012 Author Report Posted August 15, 2012 Colleagues I have been working with the organizers of the West Coast Touring Motorglider Fly In to develop the Touring Motor Glider Association...More... Quote
Newshound Posted August 15, 2012 Author Report Posted August 15, 2012 I've been using Avgas in my 912 (#113) with AV-9 from CPS. But now my AP/IA, says that Lockwood is recommending Shell Aerosport 4. What say...More... Quote
