I have a small leak from the master brake cylinder.  The fluid is showing up at the bottom of the back of the cylinder.  Jim sent me a diagram of the assembly with the measurements of the needed o-rings.  It looks like the cap should unscrew to take it apart.  I put a wrench and put quite a bit of force on it without getting it to loosen.
Has anyone done any repairs to the brake master cylinder?
Thanks;
Doug Levy
