Resilient Posted August 26, 2019 Report Posted August 26, 2019 I recently bought a Lambada and through some experimentation I am getting a glide ratio of around 15:1 at 65kts with the short tips. According to the polar I should be getting something a lot closer to 26:1. At 65kts with the prop feathered I am getting a descent of around 400-450ft/min. Again according to the polar, that should be happening at more like 85kts. Anyone else experienced similar differences? It really seems odd to be so far off. Quote
Randy Newberry Posted August 26, 2019 Report Posted August 26, 2019 I've had a 2001 tricycle gear Lambada since 2006, but have never flown it with the small tips. With the extended tips I'm pretty sure I get a glide of around 28/1 and a sink rate of around 200fpm at 65 mph. I've never really done a test on purpose in calm air, but from what I've seen over the 13 years of flying this wonderful aircraft, these are the averages I've come up with. Your numbers really do sound too high. You probably did this, but make sure you do your test early in the morning before the ground heats up, in different directions and do it a couple of times on different days. An average of those results will tell the tale. Quote
Resilient Posted August 28, 2019 Author Report Posted August 28, 2019 Yeah, I will give it a few more gos. I may just be too fast. I was pretty light when I was testing so I may have just never slowed down enough. Quote
tim wilson Posted October 27, 2021 Report Posted October 27, 2021 Resilient, Any updates on your speed polar calculation? Tim Quote
