Juha Nissi Posted September 3, 2019 Report Posted September 3, 2019 Hello, Does anybody know which Champion ignition harness should be used on G109B with Slick magneto? Br. Juha Quote
Juha Nissi Posted September 6, 2019 Author Report Posted September 6, 2019 Slick Champion customer service: "I have an M2266 approved for the Grob with a VW engine and 4300 series mag. I checked and the firing order is the same as your’s 1324. My lengths are 1-29”; 3-29”, 2-24” and 4-24”; this is the measurement between the outside of the mag cap to the center of the swedged ferrule where the plug nut seats. If this works for you in lengths it will work fine!" So you can use G109A harness to G109B. 1 Quote
