Newshound Posted August 27, 2012 Report Posted August 27, 2012 Ray, You can check the voltage at your 12 volt power outlet. Anything under 13V means the alternator is not working. Turn on the master and alternator and testMore... Quote
Newshound Posted August 27, 2012 Author Report Posted August 27, 2012 Ray, You can check the voltage at your 12 volt power outlet. Anything under 13V means the alternator is not working. Turn on the master and alternator and testMore... Quote
