Should turbulators be allowed to revolve in a GROB 2500
After removing the carburettors, I noticed that the turbulators in each manifold revolve quite easily (GROB 2500 engine) . Should they be static or allowed to revolve ? I am in the process of trying to track down the reason for a 300 rpm loss and wondered if these might be contributing to the problem.
Gareth,
In short, no they should not rotate.
See http://www.gliding.co.uk/bgainfo/technical/tns/2012/tns-3-2012.pdf
Cheers
Ian K
Gareth,
Cheers
Ian K
Thanks for the advice. It did the trick. I am now getting over 2800 rpm static.
