Collection of Posts from Yahoo Groups for Grob 109
After having my own trouble with a right crosswind which resulted in a prop strike and tour of the dirt beside the runway, I heard about a technique for taking
  • 4 weeks later...
Hello, This email message is a notification to let you know that a file has been uploaded to the Files area of the G109_Pilots group. File : /Service
Hi. Over the past couple of weeks, the cold weather has finished off my battery in the 109b. Whats the preferred replacement in the Uk?; the Odyssey PC 625 (
Thank GOD ! I can access info without passwords and other forgettable features. I am trying my best at this time to join you at Minden. Keep your fingers
Paul, We'll keep the light on for you. Please sign up as a "possible" in the Event section, 2012 Sign up tab; obviously join the TMGA first. We want you on
I use the Odessy PC625 on my 109A and it is superb! Flick the prop over very smartly, better than the regular battery. Ray
... Got the Odessy last week; its a lot smaller than the existing battery box, but the odd bit of padding sorted that out. Certainly has a lot of oomph and, as
The Touring Motor Glider Association will be holding a lunch Fly-In at the Harris Ranch restaurant/airport (3O8; SF sectional, west of Visalia; Coalinga area).
My G109B runs rich at 8,000 ft.* I am not sure if the altitude compensating Solex CD*carburetor*is doing its job. My first thought is to*replace*a
... Hi Phil, You certainly have checked the membrane and the carb oil. How did you know that you run rich at 8000ft? By landing on a high altitude airport and
As the needle wears thinner (from sliding up and down), the mixture gets richer. I assume you already made some adjustment for this wear. If not, then adjust
