Collection of posts from Yahoo Groups!
Gary * On the spot I would recommend using Mil Spec Hydraulic Aviation H5606 that is used on*all Cessna Piper etc however since*I spill a little of my
  • Replies 244
  • Created
  • Last Reply
Top Posters In This Topic
  • Newshound
    240
  • Steve Sliwa
    3
  • Richard Pearl
    2
Gary, Three thoughts: 1) have you tried phoning Cornelia? 2) the service documents don't specify the fluid but they do say the strut is a Federbein strut.
Hello, This email message is a notification to let you know that a file has been uploaded to the Files area of the Taifun17E group. File :
Hi Andre: I was finally able to remove the spring pin(2mm dia.) with a diamond drill. By grinding halfway through the pin with a 1.5mm dia. drill and then
Hi Gary: Who was your source for replacement seals, o-rings, and the other rubber component? I'm having the inner tube re-chromed and will do a complete
Hi Gil * Obviously you had a difficult one to move. For sure it would not have become loose in flight ! I decided to put a drop of oil on each at the annual
Taifun Group, I am planning to sell my Taifun 17E, 1985, SN 1066, N39MA. 90HP Limbach with electric MTV prop. Certified Experimental. 1155 hours TTE, 100
Hi to all, As you know the spark plugs Limbach LB-N41.0 are not anymore available via Limbach I did my research to identify the source and I found on one of my
Dear Group: I'm looking for a vendor to rebuild the heads for Limbach 2400EB. Most machine shops haven't worked on type 1 heads for many years and don't have
FAT in Orange. Floyd had his entire 2400 rebuilt there with incredible results. They put in stainless valves , stems and special seats. Fred. 17NT Sent from
Fred is correct, Greg and Ron at Fat in Orange are great. They resurrected my engine and solved so many problems. Heads are great.
