Great video on brake pad replacement on the blog. Jim, can you share the supplier and part number for the replacement pads?
  • 11 months later...
The replacement is relatively straightforward using the blog video from August 2014.  One caution - the spring-loaded screws should be finger-tightened with a screwdriver rather than hand-tightened. Otherwise, the screw will break through the pad from the back.
