Gfeldman Posted July 11, 2017 Report Posted July 11, 2017 Does anyone know where to find a replacement for the wires that protrude below wheel well and serve the purpose of grounding the aircraft chassis? George Feldman Quote
Jim Lee Posted August 21, 2017 Report Posted August 21, 2017 I have some on order from the factory but they will not be here for a while. In the meantime, swage a new wire onto the old wire. Nothing magic about this wire, and in my opinion, as long as you ground the plane with the cable and clamp found at the gas pumps, onto the exhaust pipe, you are better protected from a static discharge during refueling anyway. Have you ever seen this wire on GA planes? I haven't. Quote
