mikeschumann Posted May 5 Report Posted May 5 A couple of the screws holding the window assembly to my Phoenix canopy came off. It turns out that all of the screws on my canopy were loose. You should check your aircraft before you have the same problem. For the record, the screws are M3 x 10mm stainless steel with button head flanges. Each screw also has an M3 x .5mm nylon washer. These screws and washers are available from accu-components.com/us. Quote
Alex Ress Posted May 5 Report Posted May 5 Thanks Mike. Mecaplex screws are also available at Wings and Wheels. Do these look the same? https://wingsandwheels.com/mecaplex-flathead-stainless-steel-screws.html Quote
mikeschumann Posted May 10 Author Report Posted May 10 The Wings and Wheels screws are not the same. They are flat head screws. The screws used on the Phoenix look like this: Quote
