Has anyone checked out the issue involved in the latest SB from Dynon regarding the autopilot?  https://dynonavionics.com/bulletins/support_bulletin_080219.php
TECHNICAL SERVICE BULLETIN: SV42T SERVO PULLEY
Original Bulletin: August 2, 2019
PLEASE READ THIS BULLETIN IN ITS ENTIRETY BEFORE CONTACTING DYNON AVIONICS
Description
Dynon Avionics has received reports of cracked pulleys in the SV42T linear actuator servo. This can cause poor autopilot performance and presents a risk of interfering with the flight controls.
Applicability and Affected Equipment
This bulletin affects the pulley on the Dynon linear actuator, which may be found on:
  • Some Dynon Avionics SV42T Autopilot Servos (P/N 101008-003 / 101058-003)
  • Some SV32 and SV42 servos retrofitted with the Dynon linear actuator
Fig 1: Dynon SV42T servo with linear actuator
Unaffected Equipment
The following equipment is NOT affected by this service bulletin
  1. SV32, SV32L, SV32C
  2. SV42, SV42L, SV42EL, SV42C
  3. SV52, SV52L, SV52C
Additionally, Dynon Certified installations are unaffected by this service bulletin.
Interim Operating Recommendations
Due to the nature of the issue, we recommend complying with this service bulletin before further flight. However, it is up to the owner/operator to determine the airworthiness of the aircraft for flight.
Solution
Perform the following:
  1. If you received your SV42T or linear actuator assembly before 12/13/2011, it is unaffected and can remain in service. If you received your servo, or linear actuator assembly after this date, inspect it as follows.
  2. Inspect the pulley for a crack from the center of the pulley through shear screw bore. (Fig 2)
    • It may be necessary to engage the autopilot on the ground and apply force to the control surface in order to load the pulley to make the crack visible.
  3. If a crack is found, remove the servo from service and return to Dynon for repair/replacement.
  4. If no crack is found, inspect the pulley to determine whether it is affected:
    • Unaffected pulleys have a crosshatch weave pattern in their material weave and a plastic-like smooth texture. Inspect the pulley for texture and visually with a magnifier. If a crosshatch weave pattern is present (Fig 3), the pulley may remain in service.
    • Affected pulleys have a unidirectional wood-like “grain”, and a finish that appears dull looks similar to wood. If your pulley matches this description, remove from service and contact Dynon for repair/replacement. To remove the servo from service, you may opt to remove the entire servo assembly, or if more convenient you may remove the entire linear actuator sub-assembly by following the “Servo Arm / Capstan Removal and Replacement Instructions” on the Dynon Documentation Website. Whether you remove the servo or linear actuator, ensure that any remaining linkages are secured and do not interfere with flight controls. If you choose to remove only the linear actuator, disable the servo circuit electrically to prevent misleading autopilot behavior. This can be accomplished by disconnecting the wiring to the servo and/or removing its fuse or turning off its circuit breaker.
Fig 2: Affected pulley design with crack
Fig 3: Serviceable pulley design
Time in Effect
This technical service bulletin is in effect indefinitely or until superseded by a future bulletin.
Notice to Special Light Sport Aircraft (S-LSA), Dynon Certified, and other Non-experimental Customers
You are solely responsible for ensuring that your aircraft is airworthy. In the case of S-LSA aircraft, owners may need special authorization to service the aircraft if such operations are not permitted in the maintenance manual. Please refer to your aircraft maintenance manual or contact your aircraft manufacturer concerning this service bulletin.
This service bulletin does not affect installations of SkyView HDX that are approved under Dynon’s STC program.
Additional Questions?
Contact Dynon Avionics Technical Support via phone (425-402-0433) or email support@dynonavionics.com
My servos are the standard rotary style, not the linear actuator style, so I'm not affected. I doubt any Phoenix has used the linear style.
All USA Phoenix with Dynon autopilots have the SV 32 autopilot servos which are not affected by this bulletin.
