Steve Sliwa Posted April 7, 2012 Report Posted April 7, 2012 (edited) Stu Ostrander started a list of key suppliers and vendors for replacement and spare parts. Let's collect up this list in this forum and we will transcribe it to the knowledgebase. For example, you can find this initial list there already.Here is Stu's initial list:Replacement Parts and Suppliers for Grob G109BTost Master Brake Cylinder Model 7 Specification 058270 Wings and Wheels2049 Shadyside RoadLakewood, NY 14750Tel (716) 763-3213Fax (716) 763-3214http://www.wingsandwheels.comITEM DESCRIPTION 058540 (seals replacement kit) $26Door seals (weather stripping) McMaster-Carr (630) 600-3600 http://www.mcmaster.comITEM DESCRIPTION 11120A221Edge-Grip RubberSeal, Bulb Opposite Grabber, 1/8" Edge, 7/16" Bulb Width $1.51 Per Foot Spark Plugs ClubPlug http://clubplug.net/ ITEM DESCRIPTION BOSCH-WC7D $30.48 eachBrakes, Wheel CalipersAvailable from numerous on-line aircraft parts supplies as well as FBO repair shopshttp://www.aircraftspruce.com/ITEM DESCRIPTION Cleveland Part # 30-9 (Aircraft Spruce)Carburetors Victoria British LTD.14600 W 107th StreetLenexa, KS 66215Kansas City Area • 1-913-541-8500http://www.victoriabritish.com/icatalog/sg/full.aspx?Page=95Zenith/Solex/Stromberg CD-150Note: Zenith Carburetters was a British company making carburetors. In 1955 they joined with their major pre-war rival Solex Carburettors and over time the Zenith brand name fell into disuse. The rights to the Zenith designs was owned by Solex UK (a daughter company of Solex in France). The big products of Zenith were the Zenith-Stromberg carburetors used in MGs, 1967-1975, Jaguar E-types, Saab 90s and early 99s and 900s, 1969-1972 Volvo 140s and 164s, and some 1960s and 1970s Triumphs, for instance the Triumph Spitfire used Zenith IV carburetors in the North American market. In Australia the CD-150 and CDS-175 models were fitted to the hi performancetriple carburetor Holden Torana GTR-XU1. Designed and developed by Denis Barbet (Standard Triumph) and Harry Cartwrite (Zenith) in order to break S.U.'s patents, the Stromberg carburetor features a variable venturi controlled by a piston. This piston has a long, tapered, conical metering rod (usually referred to as a "needle") that fits inside an orifice ("jet") which admits fuel into the airstream passing through the carburetor. Since the needle is tapered, as it rises and falls it opens and closes the opening in the jet, regulating the passage of fuel, so the movement of the piston controls the amount of fuel delivered, depending on engine demand. Solex carburetors were until the mid 1980s used on many European cars including Volkswagen, Alfa Romeo, Fiat, Audi, Ford, BMW, Citroen, Opel, Simca, Saab, Renault, Peugeot, Lancia, Lada, Mercedes Benz, Volvo and Porsche. Solex carburetors have been made under licence by a number companies including the Mikuni company of Japan who supplied them to auto makers including Toyota, Mitsubishi and Suzuki as well as to various Japanese motorcycle makers. Mikuni originally entered into a licensed manufacturing agreement with Solex in 1960 and further developed many of Solex's original designs. The Solex brand is now owned by Magneti Marelli. The original Solex company changed its name in 1994 to Magneti Marelli France and on May 31, 2001, Magneti Marelli France partially bought its assets (including the trademark SOLEX) from Magneti Marelli Motopropulsion France S.A.S.Valve Cover gasketsAutomotive parts stores will have replacement gaskets which are used on the Grob and 4 cylinder, 2 liter Volkswagen Vanagon and Porsche 912 engines. They are available in cork and silicone rubber.gasket Delpro VS26084 R rocker cover gaskets $11.99 eaElectric Fuel pumpThe original pump, Hardi Mod H Cat No 2212 has been replaced by 4412, pressure 0.2 bar, 1m suction.(Note: supply pressure is critical. Excessive pressure will overflow the float bowl.) A substitute pump can be obtained from:Aircraft Sprucehttp://www.aircraftspruce.com/ITEM DESCRIPTION FACET fuel pump 4016312V Neg. Ground,2.5-1.5 PSI Max,17 GPH,1/8 x 27 internal pipe ports24" suction head$46.50 Edited April 7, 2012 by Webmaster Quote
Steve Sliwa Posted April 7, 2012 Author Report Posted April 7, 2012 (edited) Stu Ostrander started a list of key suppliers and vendors for replacement and spare parts. Let's collect up this list in this forum and we will transcribe it to the knowledgebase. For example, you can find this initial list there already.Here is Stu's initial list:Replacement Parts and Suppliers for Grob G109BTost Master Brake Cylinder Model 7 Specification 058270 Wings and Wheels2049 Shadyside RoadLakewood, NY 14750Tel (716) 763-3213Fax (716) 763-3214http://www.wingsandwheels.comITEM DESCRIPTION 058540 (seals replacement kit) $26Door seals (weather stripping) McMaster-Carr (630) 600-3600 http://www.mcmaster.comITEM DESCRIPTION 11120A221Edge-Grip RubberSeal, Bulb Opposite Grabber, 1/8" Edge, 7/16" Bulb Width $1.51 Per Foot Spark Plugs ClubPlug http://clubplug.net/ ITEM DESCRIPTION BOSCH-WC7D $30.48 eachBrakes, Wheel CalipersAvailable from numerous on-line aircraft parts supplies as well as FBO repair shopshttp://www.aircraftspruce.com/ITEM DESCRIPTION Cleveland Part # 30-9 (Aircraft Spruce)Carburetors Victoria British LTD.14600 W 107th StreetLenexa, KS 66215Kansas City Area • 1-913-541-8500http://www.victoriabritish.com/icatalog/sg/full.aspx?Page=95Zenith/Solex/Stromberg CD-150Note: Zenith Carburetters was a British company making carburetors. In 1955 they joined with their major pre-war rival Solex Carburettors and over time the Zenith brand name fell into disuse. The rights to the Zenith designs was owned by Solex UK (a daughter company of Solex in France). The big products of Zenith were the Zenith-Stromberg carburetors used in MGs, 1967-1975, Jaguar E-types, Saab 90s and early 99s and 900s, 1969-1972 Volvo 140s and 164s, and some 1960s and 1970s Triumphs, for instance the Triumph Spitfire used Zenith IV carburetors in the North American market. In Australia the CD-150 and CDS-175 models were fitted to the hi performancetriple carburetor Holden Torana GTR-XU1. Designed and developed by Denis Barbet (Standard Triumph) and Harry Cartwrite (Zenith) in order to break S.U.'s patents, the Stromberg carburetor features a variable venturi controlled by a piston. This piston has a long, tapered, conical metering rod (usually referred to as a "needle") that fits inside an orifice ("jet") which admits fuel into the airstream passing through the carburetor. Since the needle is tapered, as it rises and falls it opens and closes the opening in the jet, regulating the passage of fuel, so the movement of the piston controls the amount of fuel delivered, depending on engine demand. Solex carburetors were until the mid 1980s used on many European cars including Volkswagen, Alfa Romeo, Fiat, Audi, Ford, BMW, Citroen, Opel, Simca, Saab, Renault, Peugeot, Lancia, Lada, Mercedes Benz, Volvo and Porsche. Solex carburetors have been made under licence by a number companies including the Mikuni company of Japan who supplied them to auto makers including Toyota, Mitsubishi and Suzuki as well as to various Japanese motorcycle makers. Mikuni originally entered into a licensed manufacturing agreement with Solex in 1960 and further developed many of Solex's original designs. The Solex brand is now owned by Magneti Marelli. The original Solex company changed its name in 1994 to Magneti Marelli France and on May 31, 2001, Magneti Marelli France partially bought its assets (including the trademark SOLEX) from Magneti Marelli Motopropulsion France S.A.S.Valve Cover gasketsAutomotive parts stores will have replacement gaskets which are used on the Grob and 4 cylinder, 2 liter Volkswagen Vanagon and Porsche 912 engines. They are available in cork and silicone rubber.gasket Delpro VS26084 R rocker cover gaskets $11.99 eaElectric Fuel pumpThe original pump, Hardi Mod H Cat No 2212 has been replaced by 4412, pressure 0.2 bar, 1m suction.(Note: supply pressure is critical. Excessive pressure will overflow the float bowl.) A substitute pump can be obtained from:Aircraft Sprucehttp://www.aircraftspruce.com/ITEM DESCRIPTION FACET fuel pump 4016312V Neg. Ground,2.5-1.5 PSI Max,17 GPH,1/8 x 27 internal pipe ports24" suction head$46.50 Edited April 7, 2012 by Webmaster Quote
Richard Pearl Posted April 9, 2012 Report Posted April 9, 2012 A good resource is Airborne Composites, England; Tim Dewes is the head guy. Very responsive per a Grob 109 buddy (U.S.) of mine who has used the.Check out their web site Quote
David Gofman Posted January 4, 2021 Report Posted January 4, 2021 Hi Stu, please can you confirm is "1120A221" Water- and Weather-Resistant Rubber Push-on Seal with Bulb on Side, Hollow, for 1/8" Edge, 7/16" High $1.67 Per Foot and we need 10 ft length I cannot find "11120A221" Edge-Grip RubberSeal, Bulb Opposite Grabber, 1/8" Edge, 7/16" Bulb Width $1.51 Per Foot https://www.mcmaster.com/1120A221/ I like this design https://www.mcmaster.com/12335A44/ but I am not sure will fit for my Grob 109B Thanks David Quote
Albin Posted February 6, 2025 Report Posted February 6, 2025 Hi The door seals can only be bought in US. For EU i have used this one, it has the same dimensions and material https://www.profillagret.se/med-sidot%C3%A4tning/60-kantliste.html Quote
